TheMitchells Posted March 6, 2024 Posted March 6, 2024 If I add cavity wall insulation to my bungalow, with the intention of making it as airtight and insulated as possible for a limited budget, do I need to cap the top of the cavity? I do plan to remove the first couple of layers of tiles and try to join the cavity insulation to the attic insulation. So presumably not. I shall add something to ensure airflow into the roofspace. Then i need to ask about the vapour barrier and the best way to add that. But one thing at a time. 🙂
BotusBuild Posted March 6, 2024 Posted March 6, 2024 Just now, TheMitchells said: join the cavity insulation to the attic insulation From bitter experience this can be difficult to achieve from inside, so taking back tiles and "working from outside" maybe a clever solution. Do be careful NOT to block off any designed natural ventilation to the attic space as you could end up with condensation problems up there. I wouldn't cap off the cavity as again, there is probably some natural ventilation going on to keep condensation down in the cavity itself. 1
ADLIan Posted March 6, 2024 Posted March 6, 2024 Generally a masonry cavity wall (insulated or not) should not be ventilated - nothing to do with reducing condensation risk. A open cavity must be sealed at the top and must not link with any ventilation into the roof space/roof ventilation route - it’s a fire safety issue. 2
JackofAll Posted March 9, 2024 Posted March 9, 2024 Have left the top of our cavity open. The dritherm will meet the blown cellouse(when I get around to pumping it) is this a no no? Engineer seemed happy.
