Hi All
I am finally at that point of putting paint on the walls - I feel like there is 1000's m2 to do!
All the walls and ceilings are mist coated
I am planning on giving the walls light sand down by hand with a pole sander, what grit would people recommend?
Also what is a good roller that people could recommend for me to emulsion the walls & ceilings? I have bought lots a cheap ones in the past but they have all being rubbish
Any advice/recommendations very helpful
Any general painting tips appreciated too! - was planning on doing the ceilings, woodwork and then walls in that order
180 grit.
get a professional adjustable pole and a frame that takes a roller sleeve with a fitting in both ends, not a sleeve that pushes onto a cage roller handle, you will get a better even pressure on the roller.
Hamilton perfection roller sleeve 12 inch, medium pile. £20 for 3.
get 4inch for the edges.
Thank you both I will look into these now
Also does this make sense paint wise:
Ceilings/Coving - Dulux Trade Vinyl Matt
Walls - Dulux Trade Diamond Matt (for all downstairs and landing) planning to use vinyl matt for bedrooms
Woodwork - Dulux Trade Diamond Eggshell
