craig Posted February 15, 2024 Share Posted February 15, 2024 10 hours ago, Iceverge said: Maybe @craig has a better detail. Also his expert eye might be able to judge the installers effort better than me. Having a look over the topic, need to ascertain what the problem is and the end question and will come back to it later today. 1 Link to comment Share on other sites More sharing options...
JackofAll Posted February 15, 2024 Author Share Posted February 15, 2024 13 hours ago, Iceverge said: There may be an issue with the clearance being too tight on the sides of the windows with hinges and I'm unsure of your planned window board detail as it'd be very tight even with OSB window boxes when your frames only have 32mm clearance Link to comment Share on other sites More sharing options...
JackofAll Posted February 15, 2024 Author Share Posted February 15, 2024 (edited) 70mm from opening sash as the inner leaf opening was 20mm wider each side. The bottom section of inside leaf was cut down so approx 50mm to th bottom of opening sash. Edited February 15, 2024 by JackofAll Omission Link to comment Share on other sites More sharing options...
JackofAll Posted February 15, 2024 Author Share Posted February 15, 2024 3 hours ago, craig said: Having a look over the topic, need to ascertain what the problem is and the end question and will come back to it later today. Thanks, Originally ply/osb boxes were to cantilever off inner leaf butting up to frame of window. Due to strapping sloping up toward the bottom of window this cannot be achieved as the straps will fowl the ply/osb. How do I overcome this? Will the straps need to be removed? Link to comment Share on other sites More sharing options...
craig Posted February 15, 2024 Share Posted February 15, 2024 (edited) The first question is there appears to be no cill extension at the bottom of the window. Where is the cill extension, was this offered with the windows or was it offered without. If without, was it because the window is face drained or are the windows bottom drained? If bottom drained, then how is the external cill connected to expel the water or is the stone cill being used? You'll know if it's face drained, as it will have slots on the frame externally and cover caps over the slots. If the cill extension was present, then the window sits up 30mm approx. and you don't have the issue but you are where you are. Take of the bottom brackets, fit an L bracket instead to the outer wall and you're not bridging the cavity tying back to the inner wall. You'll pick up the below brackets in Screwfix Secondly, ground floor, where's the lockable handle on the window? It should have one, you'll need lockable handles for your home insurance to be valid unless this is an escape window. You should have approx. 20mm of the frame all around to overlap for finishing, the less the better as you're going to be tight for tolerances. Edited February 15, 2024 by craig Link to comment Share on other sites More sharing options...
JackofAll Posted February 15, 2024 Author Share Posted February 15, 2024 4 hours ago, craig said: The first question is there appears to be no cill extension at the bottom of the window. Where is the cill extension, was this offered with the windows or was it offered without. If without, was it because the window is face drained or are the windows bottom drained? If bottom drained, then how is the external cill connected to expel the water or is the stone cill being used? You'll know if it's face drained, as it will have slots on the frame externally and cover caps over the slots. If the cill extension was present, then the window sits up 30mm approx. and you don't have the issue but you are where you are. Take of the bottom brackets, fit an L bracket instead to the outer wall and you're not bridging the cavity tying back to the inner wall. You'll pick up the below brackets in Screwfix Secondly, ground floor, where's the lockable handle on the window? It should have one, you'll need lockable handles for your home insurance to be valid unless this is an escape window. You should have approx. 20mm of the frame all around to overlap for finishing, the less the better as you're going to be tight for tolerances. Face drained window and lime stone cill. Tbh never heard of an extension until reading your post. Am I right in saying drill the cill to mount L bracket to and then screw up into window frame? Now that you mention lockable handles, never occurred to me, none of the windows have them, is this something that I should have requested or something that should have been provided? Link to comment Share on other sites More sharing options...
craig Posted February 15, 2024 Share Posted February 15, 2024 (edited) 2 hours ago, JackofAll said: Am I right in saying drill the cill to mount L bracket to and then screw up into window frame? To the external wall then up into the frame, it’s going to be a bit of a ballache tbh. 2 hours ago, JackofAll said: is this something that I should have requested or something that should have been provided? Something that should have been requested and pointed out to you tbh, for the reason mentioned. Edited February 15, 2024 by craig 1 Link to comment Share on other sites More sharing options...
Iceverge Posted February 16, 2024 Share Posted February 16, 2024 10 hours ago, craig said: Secondly, ground floor, where's the lockable handle on the window? It should have one, you'll need lockable handles for your home insurance to be valid unless this is an escape window. Didn't have these either, Maybe it's an Ireland vs UK thing. Link to comment Share on other sites More sharing options...
craig Posted February 16, 2024 Share Posted February 16, 2024 Just now, Iceverge said: Maybe it's an Ireland vs UK thing It’s an insurance thing, policy should be checked regarding lockable windows and doors. They can void any insurance claim for break ins/stolen items as a result. One of the biggest cartels going and they’ll take any reason not to pay out. 1 Link to comment Share on other sites More sharing options...
Iceverge Posted February 16, 2024 Share Posted February 16, 2024 Just checked my policy, it says nothing about locked windows. just closed and fastened. @craig have you had a glance at my suggested detail for the jambs and head if the window? Any comments? Link to comment Share on other sites More sharing options...
craig Posted February 16, 2024 Share Posted February 16, 2024 (edited) Yeah, it’s a good option if he has the space for it. I think at 20mm the window at 90-degree open is going to be a bit tight. 10 to 15mm overlap would be ideal in this situation. Edited February 16, 2024 by craig Link to comment Share on other sites More sharing options...
Iceverge Posted February 16, 2024 Share Posted February 16, 2024 Just now, craig said: Yeah, it’s a good option if he has the space for it. I think at 20mm the window at 90-degree open is going to be a bit tight. 10 to 15mm overlap would be ideal in this situation. I was thinking that but using a scaled drawing I couldn't see the screwing into the frame going well if it was any wider. I guess there is the option still to use the 20mm setback to have slightly splayed reveals. Link to comment Share on other sites More sharing options...
craig Posted February 16, 2024 Share Posted February 16, 2024 I’d CT1 it in place if there wasn’t a screw fixing. They problem he’d have is movement of the building/window. Link to comment Share on other sites More sharing options...
Iceverge Posted February 16, 2024 Share Posted February 16, 2024 Adhere the J bead to the window you mean? wouldn't that be very slow and messy? Link to comment Share on other sites More sharing options...
JackofAll Posted February 17, 2024 Author Share Posted February 17, 2024 Thanks lads, Will have a look tomorrow, would CT1 really be strong enough to hold the bead? Herself has suggested cutting OSB and slipping it in behind the straps on the jambs and screwing through the straps to hold OSB in place and then sticking plasterboard to that. Would imagine that we'd need to put membrane on first before fitting OSB. An option or just extra work? Link to comment Share on other sites More sharing options...
Iceverge Posted February 17, 2024 Share Posted February 17, 2024 The bottom of the window will be the issue I think. How much clearance is there under the sash to the edge of the frame? How thick are you planning on having your window boards? Link to comment Share on other sites More sharing options...
JackofAll Posted February 18, 2024 Author Share Posted February 18, 2024 (edited) 20 hours ago, Iceverge said: The bottom of the window will be the issue I think. How much clearance is there under the sash to the edge of the frame? How thick are you planning on having your window boards? 32mm, but I cut the innerleaf block down about 15mm so 47 ish, hard to hold a consaw in the horizontal position:-) Edited February 18, 2024 by JackofAll Link to comment Share on other sites More sharing options...
JackofAll Posted February 18, 2024 Author Share Posted February 18, 2024 25mm window board as it seems to be the most common Link to comment Share on other sites More sharing options...
Iceverge Posted February 18, 2024 Share Posted February 18, 2024 Ok how about this. Apply the tape and membrane as above to the 4 sides to air seal the window. Including the brackets. Then but one of these. And screw it into the bottom of the window using something like this. It'd be better to get the screws into the steel frame of the window. There's a rough sketch. 1. Red tape and airtighess member. 2. Green angle bracket 3. Orange self drilling screw into steel frame. 4. Blue window board. You can level the inside of the board with timber on top of the wall. Or perhaps leave a slant towards the room. It'll be less lightly to catch the opening window then with only 7mm clearance. Link to comment Share on other sites More sharing options...
JackofAll Posted February 18, 2024 Author Share Posted February 18, 2024 47 minutes ago, Iceverge said: Ok how about this. Apply the tape and membrane as above to the 4 sides to air seal the window. Including the brackets. Then but one of these. And screw it into the bottom of the window using something like this. It'd be better to get the screws into the steel frame of the window. There's a rough sketch. 1. Red tape and airtighess member. 2. Green angle bracket 3. Orange self drilling screw into steel frame. 4. Blue window board. You can level the inside of the board with timber on top of the wall. Or perhaps leave a slant towards the room. It'll be less lightly to catch the opening window then with only 7mm clearance. Thanks @Iceverge, will be starting the reveals this week, this is a great help. Just wondering would 15mm PB on reveals be better or not? Link to comment Share on other sites More sharing options...
Iceverge Posted February 19, 2024 Share Posted February 19, 2024 It'd be a bit stronger but not massively. It'd be a thicker J bead too so maybe harder to screw into the correct place. The sketches I did use your actual profile. You can see how tight it is. . 1 Link to comment Share on other sites More sharing options...
JackofAll Posted February 23, 2024 Author Share Posted February 23, 2024 (edited) There was a gap left over each window/door where dpc comes out, due to nothing to foam against. Am thinking of cutting a piece of PIR to fit in from inside up to the inner face of outer leaf ontop of window so there is something to foam against. As PIR has a different u value to dritherm 37 would there be any issues in doing so? Also any ideas how to keep pir in place? Edited February 23, 2024 by JackofAll Link to comment Share on other sites More sharing options...
