markharro Posted February 5, 2024 Posted February 5, 2024 I am trying to find some 12mm thick and around 60mm high MDF lengths to use as skirting that is flush with our plasterboard. Can anyone suggest a source? thanks
SimonD Posted February 5, 2024 Posted February 5, 2024 21 minutes ago, markharro said: I am trying to find some 12mm thick and around 60mm high MDF lengths to use as skirting that is flush with our plasterboard. Can anyone suggest a source? thanks Just approach a local timber merchant as they will almost always have machinery to both cut and machine profiles to your needs. 1
ProDave Posted February 5, 2024 Posted February 5, 2024 Check the thickness but it might be a standard product from Howdens https://www.howdens.com/joinery/architrave/howdens-42m-square-white-mdf-architrave-obj-sku-family-mod0821
oliwoodings Posted February 5, 2024 Posted February 5, 2024 If you're after square edge could you not just rip down full sheets yourself?
ProDave Posted February 5, 2024 Posted February 5, 2024 2 minutes ago, oliwoodings said: If you're after square edge could you not just rip down full sheets yourself? But they would only be 2.4M long so more joints compared to buying MDF skirting.
oliwoodings Posted February 5, 2024 Posted February 5, 2024 Just now, ProDave said: But they would only be 2.4M long so more joints compared to buying MDF skirting. Fair point, depends how much is being done and dimensions of the room I guess.
markharro Posted February 6, 2024 Author Posted February 6, 2024 The Howdens product is quite close but 14.5mm! Yes I could rip sheets but that is a pain and the thing with the ready prepped skirtings is that you can also buy them pre-primed.
