Impossible to tell from the drawing. It should be detailed elsewhere. that looks like a planning drawing, rather than a construction drawing, should be detailed in a schedule or note, and a section drawing will give the dimensions and shape of the overhang etc. some snippets from ours:
In the end, we went for a smaller overhang, boxed in, and rendered over. Looks the business. This is all joinery and kind of design change you can make along the way without too much drama.
Edited by Conor
Not according to our planning dept!
Yours looks good
Yours looks good
I think planners have bigger things to worry about. A slight change to the detail won be an issue. Assuming you're not in a conservation area or similar.
