ronco101 Posted January 10 Share Posted January 10 Hi All, We are embarking on a self-build and the ASHP was installed yesterday and we are awaiting the commissioning engineer tomorrow to turn on and start heating. I was a little alarmed by the our ASHP supplier planning to just operate the ASHP at its standard operation rather then operating a thermal cycle. From what I have read on line this is important for the concrete screed performance and any floor finishes installed later. I spoke with our tile installer and tile adhesive supplier and they have recommended the following regime which is more or less a 14 day cycle that involves, 5 days of gradual heat increase (2-3C per day) , maintain at expected operating temp for a further 4 days, before a 5 day gradual decrease in temperature. My question is with regard to the expected operating temperature, which I presume is the outflow temperature of the ASHP (45 degree), that the underfloor heating pipework's will be supplying to the screed for these 4 days. My understanding is that the thermostats will be overridden temporarily for the commissioning and the slab will be consistently heated with this 45 degree water - am I correct? If this is so then theoretically will the house be extremely warm for a few days as the slab should come close to the 45 degree temperature? Link to comment Share on other sites More sharing options...
JohnMo Posted January 10 Share Posted January 10 My UFH has never reached 45 degrees, for UFH - it never will. I just started mine as low a temp as I could, ran for a couple days, increased slowly to about 35 and stopped there. 1 Link to comment Share on other sites More sharing options...
ringi Posted 23 hours ago Share Posted 23 hours ago How long have the screed been down for? Link to comment Share on other sites More sharing options...
JohnMo Posted 22 hours ago Share Posted 22 hours ago 55 minutes ago, ringi said: How long have the screed been down for? The OP hasn't been on since March so unlikely to answer Link to comment Share on other sites More sharing options...
