BotusBuild Posted January 9, 2024 Posted January 9, 2024 Internal floors and walls are on my mind, keeping me awake at night. Which should I do first? Floors first? Once complete you have to protect them for a (long) period of time from scrapes, bumps, plaster splashes etc., but once done you know where the walls have to finish 🙂 Walls first? Do all your plastering and any painting etc. without worrying about damage to the floor. Do you bring the plaster board/plaster down to the base floor (18mm plywood), or leave a gap? How big a gap? So, I am thinking walls first. FYI, I will be be laying UFH on the upper floors
ProDave Posted January 9, 2024 Posted January 9, 2024 Walls first. Leave a gap at the bottom a bit wider than the flooring you expect to lay. Skirting board was invented to cover the gap between the bottom of the wall and the floor. 1
BotusBuild Posted January 9, 2024 Author Posted January 9, 2024 20 minutes ago, ProDave said: Skirting board was invented to cover the gap between the bottom of the wall and the floor. No room for no gap then 🙂
