I'm looking for quotes, other than the silly answers I got from Network Rail, for hardcore.
Hilliard has specified 30-50 dia. so I'm assuming that I just want clean with no fines, would anyone agree with this assumption.
The network rail stuff is, as far as I know, what some including me have used as a replacement (with Hilliard's blessing) for the specified 28-50 (from memory) angular no fines material.
It's been a while, but I seem to recall that this is an unusual spec in the UK, which is why recycled rail ballast became of interest.
If you can find a source of hard, angular, no fines material with a slightly different size range, I'd just give Hilliard a call and ask whether he's happy with it as a replacement. Not sure whether a revised formal spec will be required - worth checking with your building inspector.
I'm pretty sure the spec for ours was clean, washed, no fines, 18 - 35, which is not that easy to get here.  I seem to remember we paid a fair bit for ours, as we weren't aware of the railway ballast option.
Just checked our spec and it's actually 30-50mm. Not sure where I got the 28mm lower number from!
Half the area of what will be the new house footprint is where I have just knocked down my original garage. This area already has a 300mm layer of 40mm down MOT1. Obviously  with the price of hardcore I am reluctant to just dig this out and skip it. What are the views on using this as a base layer over the complete area and then topping it up with 20-40 clean. Or alternatively trying to mix this material in with 20-40 clean so you end up with a hybrid mix.
And another question :)
I've just spoken with two local quarries. The first one is charging just over £15 + VAT per ton for 40mm washed limestone, the other is charging just under £10 + VAT per ton for 40mm washed hard chalk.
Obviously the latter is the favourite but is hard chalk acceptable??
Edited by RichS
Spelling
Under my PH slab I have 250mm type 1 compacted and on top of that 50mm granite fines then the insulation. What you need must surely depend on the ground conditions.
I doubt mixing is going to be the way forward, as it will affect the way loads are transmitted. As I understand it, no fines means that the larger pieces will lock together under load.
I wouldn't speculate about something as literally fundamental as this. Hilliard is a really helpful guy. He knows your house and your ground conditions. Give him a call and I'm sure he'll set you straight within a couple of minutes.
Hi @PeterStarck, Thanks for that, I assume you mean 5mm granite fines??
So the digger man started today. The existing MOT1 hardcore that I mentioned earlier, I am digging down 150mm deeper than required and then going to spread this MOT1 to form a sub-base for the 30-50 clean. The slab will still end up with the 300mm of clean as required but sat on a MOT1 sub base.
Just to re-ask a question that no one took up on, has anyone used hard chalk for their hardcore??
