1 hour ago, MikeGrahamT21 said:
Liquid membrane on all junctions, parge coat on the rest
Thanks Mike, does that include the top row of blocks that meet the roof or does the air tight membrane at ceiling level take care of that?
So anything which has the potential to move and crack needs it, so think along the lines of wall plate timber against blockwork interface, this needs the liquid membrane as the materials will expand at different paces and inevitably crack, a stretchy liquid membrane will sort this permanently. Covering with airtight membrane from the roof could lead to air getting behind the membrane.
Parge is a waste of time and expense
By using it Have you given up on trying to seal the dot and dab
My personal preference is to wet plaster with bonding coat and then multi finish but it does take time to dry, I’ve never been a fan of dot and dab, too much that you can’t see can go wrong
11 minutes ago, twice round the block said:
Hard plastering is coming back into fashion after 30 year's of dot and dab
Long overdue, IMHO.
Any tips on what to look for/how to properly seal the dot and dab? Just a matter of sealing all round the perimeter of each board?
according to manufacturers specs, yes. But a lot can happen in the 2.8m2 of area behind that one board
however aircrete blocks are very common background to be sticking on to, they shrink and crack very easily resulting in air leakage. Even denser aggregate blocks can be hard to get the mortar to make a perfect seal, which is where the parge coat came in, but it’s not thick enough to withstand shrinkage.
For me, avoid D&D at all costs
Edited by MikeGrahamT21
Just stress to your dabbers that it needs to be sealed properly
It really isn’t difficult A continuous line of adhesive around every perimeter and frame Every socket and pipe
As I’ve stated before If you put an airtight layer on Your dry liners won’t bother to do the above It would do any harm to put a Parge coat on But it won’t make any difference to airtightness But if you do Call it by the name on the bag Sound block
As a business I still use a couple of thousand bags per year Mainly housing associations Always for sound transfer reasons
15+ years ago we used it on virtually everything Due to block work being left snotty with joints missing
Now they would get through there pre plaster inspection
11 hours ago, twice round the block said:
Hard plastering is coming back into fashion after 30 year's of dot and dab and the failings it has.
Problem being lot's of the old tradesmen don't exist anymore.
Afaics It's still the main way of plastering block walls here.
