Hi
I've seen a few posts on here where it's been mentioned that if you're using Pex-Al-Pex pipe, you can bring the pipes up from the floor in the centre of radiator... looping the pipe round and down behind the radiator then into the TRV/lockshield.
Has anyone got any pics of what this looks like when done? My plan is to convince the missus this is a good option rather than going with copper from the tails to the floor.
1 hour ago, RichJ said:
Hi
On 05/12/2023 at 13:01, nod said:
Any issues in plasterboarding over 15mm+ @nod?  keeping the boards all in line on the same dab depth so it doesn't end up a bit wavy.  What's the max you'd ever dab over?
Thanks for the photo Nod.
But how would you connect the plastic pipe to the lockshield/trvs? I'm assuming it's not into the bottom of the valves like copper pipes coming up from the floor would do.
