crispy_wafer Posted November 18, 2023 Posted November 18, 2023 Have to admit I'm learning slowly with what can and cannot be done, but last night I was playing with 15mm brass wallplate, and a 1/2" - 15mm hep20 female socket. I found I could take the nut and olive away from the wall plate and thread the hep20 female socket on to it. Can I do this, or am I likely to cause problems for myself at a later date? Thx Marek
ProDave Posted November 18, 2023 Posted November 18, 2023 I'll give my reply and let the proper plumbers come in a minute to agree or disagree. It will work, BUT it is not right. The fitting your HEP adaptor is intended to connect to looks almost the same, but the edge of threaded pipe it fits to has a pretty square edge. Your fitting intended for a copper pipe with an olive has the end machined out to match the olive so presents just a very thin edge of pipe. 1 1
crispy_wafer Posted November 18, 2023 Author Posted November 18, 2023 Thankyou, I wont entertain that idea then, I've got 1/2 f to 1/2 f wall plate adapters that I'll continue to use.
joe90 Posted November 18, 2023 Posted November 18, 2023 Or a short piece of copper pipe from the olive conn then hep20 ! 1
