I am replacing a 3 gang 15cm x 8cm dimmer switch in my kitchen with normal switches. Something has gone pop on one of my lighting circuits, and since I have non-dimming LEDs installed since 2013 this is one suggestion after a few years.
I seem to have found a hole in the market with noting between cheap & perhaps nasty (<£15) and stupidly expensive (£75-100 + likely to have click switches like my primary school in 197x).
I'm looking at approximately Schneider / MK level with a brushed metallic finish or brushed metal front plate roughly to match the rest of the room.
Can anyone recommend - an hour looking has found nothing suitable?
Plan B will be a 4 gang with one left unconnected.
Chees
Ferdinand
4 gang grid switch is your only answer with one fitted with a blank.  I have never seen a 3 gang switch in a 2G wide front plate.
Or if going for new dimmers, just buy any make of new dimmer and swap the modules over onto your old front plate.
Is this any good?
https://www.rselectricalsupplies.co.uk/products/schneider-ultimate-flat-plate-stainless-steel-3g-2w-light-switch-gu12322wss
Here's an example of a retro flick switch in that format from SF in about 10 finishes. Lots around afaics, but seem mainly for Felicity to install in her antique house in West Hampstead:
https://www.screwfix.com/search?search=3+gang+lghtswitch&numberofgangs=3_gang&switchoperation=toggle&switchproducttype=light
And here's the only rocker on I can find, which looks cheap:
https://www.amazon.co.uk/Varilight-3-Gang-Rocker-Switch-Rockers/dp/B01DM43X4K/
F
Final question for @ProDave.
If I go with a screw-less faceplate, which most of them seem to be, will this cause problems mating to a standard recessed back-box which has the fittings for a screwed faceplate?
Cheers
A screwless faceplate still fixes to the back box with standard screws, and then a decorative cover clips on to cover the lot hiding the screws.
Some of the Varilight stuff is a king of low voltage master / slave unit.
  • 2 weeks later...
Install now done.
Used a LAP 4-Gang which was in stock, and it now works fine.
It was indeed a dead dimmer unit for that circuit.
Thanks for the repies.
Ferdinand
