OK, so I need to cover the timber cavity closures between the block work and the windows ready for rendering (traditional sand and cement).
Im thinking:
Staple building paper/membrane to the timber so that the timber doesn't pull the water out faster than the blockwork.
100mm EML mesh roll which overlaps onto the blocks.
Two unresolved thoughts:
Stainless or galvanised EML?
How to attach the EML?
Decisions, decisions. :/
Just regarding stainless or galv I have had the galv rust before especially at the cut ends.
So be careful to re coat cut ends or try to avoid cheaper poorly galvanised stuff,
there is a lot of poor quality galv fencing around that is rusting after only 5 years.
If just for the reveals can you use a modified bag render and include the fibre mesh in it, what are your corner beads, after using plastic I don't think I will ever buy a galv one again.
My heart is telling me stainless.
Renderer has specified plastic beads.
