what's the general consensus on the colour of around a bifold?
bifold is aluminium, anthracite and the walls are white. do I use white caulk and blend it with the wall, risking a white strip on the door, or do I use anthracite caulk and risk seeing it on the wall?
thanks
If you can get a good colour match to the frame I would go with the anthracite, white against a different white can look horrible
My doors and window frames are also anthracite both external and internal.
Most of my walls are off white or light grey and the caulking is in white so it is ok.  I have one room that has a bold  greenish colour and the decorator has used white caulk.  It’s ok from a distance but not ideal.  This is the problem you and I have.
like me you’ve probably found getting coloured caulk seems to be difficult - though coloured silicone sealant does seem more available.
If you have a wall colour choice that no way matches any suitable caulk I think the only option would be to paint the white caulk to match the walls.  Or a very and minimum bead of sealant in anthracite.
hopefully someone here has the perfect solution and a supplier for coloured caulk.  I have yet to determine this myself.
I suspect quality masking tape may be involved in the solution.
Edited by Bozza
completely agree with this comment, second this
