Hastings Posted November 28, 2023 Posted November 28, 2023 (edited) I am going into my first fully off-grid winter in southern Scotland (Glasgow latitude) so I can't yet be definitive (and even then it would be just the one year) but looking at the data I am finding that my PV production is quite a bit less than the estimate obtained from online tools like PVGIS. Two days ago my 1.9kW PV array produced 270Wh on a grey drizzly day. That's not enough to power the constant background load of charger/inverter (30W), UV water filter (30W), MVHR (15W) and system losses. Edited November 28, 2023 by Hastings 1
SteamyTea Posted November 28, 2023 Posted November 28, 2023 24 minutes ago, Hastings said: Two days ago my 1.9kW PV array produced 270Wh on a grey drizzly day
Iceverge Posted November 28, 2023 Posted November 28, 2023 29 minutes ago, Hastings said: I am going into my first fully off-grid winter in southern Scotland (Glasgow latitude) so I can't yet be definitive (and even then it would be just the one year) but looking at the data I am finding that my PV production is quite a bit less than the estimate obtained from online tools like PVGIS. Two days ago my 1.9kW PV array produced 270Wh on a grey drizzly day. That's not enough to power the constant background load of charger/inverter (30W), UV water filter (30W), MVHR (15W) and system losses. Is that a factor of sunshine or is it something else? Having looked at it I think in the British isles you need to burn something to be practically off grid during the winter. A small inverter generator would get you through no?
Hastings Posted November 28, 2023 Posted November 28, 2023 17 minutes ago, SteamyTea said: Added it in to what?
SteamyTea Posted November 28, 2023 Posted November 28, 2023 2 minutes ago, Hastings said: Added it in to what? Go to the start of the topic, for some reason it linked to the end of it.
billt Posted November 28, 2023 Posted November 28, 2023 54 minutes ago, Hastings said: I am going into my first fully off-grid winter in southern Scotland (Glasgow latitude) so I can't yet be definitive (and even then it would be just the one year) but looking at the data I am finding that my PV production is quite a bit less than the estimate obtained from online tools like PVGIS. Two days ago my 1.9kW PV array produced 270Wh on a grey drizzly day. That's not enough to power the constant background load of charger/inverter (30W), UV water filter (30W), MVHR (15W) and system losses. PVGIS gives an estimate of average production. It isn't a prediction. Solar energy is highly variable, especially at this time of year when there's a very small period when the sun is high enough to generate anything. The low sun angle is likely to make any shading by trees etc worse. Our approx. 15kW array generated 3 kWh on Monday, not that much more than yours, proportionately, and we are a lot further south. Trying to be self sufficient in electrical energy in the UK is not economically possible, and probably not practicslly possible either. FWIW PVGIS predicts 377kWh generation for November. In 2021 it generated 276kWh, 2022 201 kWh and this year looks to be 310 kWh if we get 2 days of sun as forecast.
Hastings Posted November 28, 2023 Posted November 28, 2023 26 minutes ago, SteamyTea said: Go to the start of the topic, for some reason it linked to the end of it. Still none the wiser, sorry, but the 2000W challenge is right up my street.
SteamyTea Posted November 28, 2023 Posted November 28, 2023 9 minutes ago, Hastings said: Still none the wiser, sorry, but the 2000W challenge is right up my street. Really just to highlight how difficult a time you are going to have going off grid.
Hastings Posted November 28, 2023 Posted November 28, 2023 1 hour ago, SteamyTea said: Really just to highlight how difficult a time you are going to have going off grid. Ah, that explains my puzzlement, thank you. Have been off grid for the whole 5-6 year build and loving it. Would have preferred to have less power and fewer mod cons but building standards and public health dept (private water supply police) of the local authority stood in the way of that ideal home. 1
Square Feet Posted November 29, 2023 Author Posted November 29, 2023 18 hours ago, Hastings said: I am going into my first fully off-grid winter in southern Scotland (Glasgow latitude) so I can't yet be definitive (and even then it would be just the one year) but looking at the data I am finding that my PV production is quite a bit less than the estimate obtained from online tools like PVGIS. Two days ago my 1.9kW PV array produced 270Wh on a grey drizzly day. That's not enough to power the constant background load of charger/inverter (30W), UV water filter (30W), MVHR (15W) and system losses. Thanks that's interesting, if disappointing.
Dillsue Posted November 29, 2023 Posted November 29, 2023 7 hours ago, Square Feet said: Thanks that's interesting, if disappointing. Don't be too disappointed as PVGIS predicts 3470 kwh/Yr for us and our actual is 35xx - 37xx/Yr since 2015. The post you were commenting on was quoting a 1.9kwp system which is a modest system and pretty small if you're wanting to go off grid. 1
Square Feet Posted December 7, 2023 Author Posted December 7, 2023 (edited) I saw this on eBay today. Here's what the text says to save you having to translate it: " V2H, 5 kVA (4 KW), CHAdeMO, station allowing you to power receivers from a car battery, only EV with CHAdeMO charging socket It changes the direct current from the electric car battery (CHAdeMO socket). Through transformations in the V2H inverter, we obtain alternating current for home or business use. It can only work with cars equipped with a CHAdeMO charging socket It is a portable device, suitable for use in a company or household emergency power source on board the vehicle as a power source camping, family trip in service cars where an alternating current source is needed Invaluable in the era of autumn and winter interruptions in electricity supplies - "blackout" Basic information: Country of origin: China Business ; ELECTWAY Model: V2H Certification: CE, UL Warrants: 1 year Weight 25 kg Wooden transport packaging Delivery time: device in stock Edited December 7, 2023 by Square Feet
