suryabhan singh Posted October 17, 2023 Posted October 17, 2023 I am looking to buy wardrobe not fitted.I get few Quotes and material they use 15mm A grade melamine board.is it good enough material?
bassanclan Posted October 18, 2023 Posted October 18, 2023 No, just buy something from Argos if you want that sort of quality
ToughButterCup Posted October 18, 2023 Posted October 18, 2023 No. 'A' grade is almost irrelevant: it's the depth of the shelving - and the support it gets - that counts; 15mm will sag with the average amount of stuff families cram into a wardrobe. Thats why we use the Elfa storage system now - you can't cram stuff in that system without it being obvious that that's what you have done. We are retired / retiring and trying hard to downsize everything. Our family has 'disappeared', all three of them have their own houses now. Thank goodness. There is lots of advice on YooChube ....
Ferdinand Posted October 18, 2023 Posted October 18, 2023 For non-sagging shelves I use something more like varnished, or painted, 18mm OSB. 18mm has the advantage that it is the most common standard size, so less expensive per standard amount. Or even similar strength MDF. But that is more moisture-vulnerable.
Gone West Posted October 18, 2023 Posted October 18, 2023 6 hours ago, ToughButterCup said: Thats why we use the Elfa storage system now +1 for Elfa. We've used that system for some time now, and it's really 'flexible', in a good way.
