Hello
We're building a self build detached house.
The plasterer says the internal door casing need to be fitted first before boarding and skimming. The joiner says, the casing should be fitted after plasterboard and skimming.
Should internal door casing be fitted before or after plasterboard and skimming?
Thanks
Any that are on to block work need fitting first
Those onto stud walls can be done
either way
