Can gas pipes be ran on warm side of cold roof?
My gas boiler will eventually move into the loft space. I want to run all the pipework in readiness for that (gas, water, flow, return), before I re-insulate the loft but leave it all disconnected ready for my gas engineer to connect to when I do move the boiler.
I plan to run all 4x pipes under the loft insulation, so on the warm side, is there any problem with running gas pipes within wool roll insulation?
  • 1 month later...
