Outside wall becoming an inside wall
have a couple of these on our build, example below above the pitched roof. Wonder if we should use another course of marmox just inside the pitched element to thermal break it. Cant run them the whole length as they would be visible so there will stiill be an element of sideways leeching. Losses too small to worry about ? How would they be calculated ?
I have used Marmox where we have a single storey element abutting 3 storey, so they are on the steel beam.  I think they are better at stopping side-to-side cold bridges than up /  down, as they have the concrete type vertical cylinders, but better than nothing.
