MortarThePoint Posted September 3, 2023 Posted September 3, 2023 What, if anything, is needed a ducting connections? For example where a 90 degree bend pushes into the end of a straight pipe. Is any pressure testing required?
Conor Posted September 3, 2023 Posted September 3, 2023 Depends on the material. I used a little acrylic sealant on the connections then taped over the join with aluminium tape. 1
JohnMo Posted September 3, 2023 Posted September 3, 2023 If it the white plastic duct you are thinking about you can use plastic pipe solvent cement also.
MortarThePoint Posted September 3, 2023 Author Posted September 3, 2023 53 minutes ago, Conor said: Depends on the material. I used a little acrylic sealant on the connections then taped over the join with aluminium tape. 2 minutes ago, JohnMo said: If it the white plastic duct you are thinking about you can use plastic pipe solvent cement also. It's Manrose PVC ducting, a mixture of 125mm circular and 204x60 rectangular. I'm not wanting it all to be set solid and unmaintainable. Fear of commitment perhaps. Aluminium tape sounds good and I could use Everflex 195 which has been my go to for other sealing jobs. Its datasheet mentions PVCu, so hopefully OK.
MikeGrahamT21 Posted September 3, 2023 Posted September 3, 2023 https://www.bpcventilation.com/self-seal-conn-duct-to-duct?gclid=CjwKCAjw3dCnBhBCEiwAVvLcu4L5nW-j87wCt74jYJ-HdWNCoDhfo0Iwdxiae9q02dEWGUoWjiRwfBoCAVsQAvD_BwE you can get self sealing joints
