What design of shelf brackets to use with MF walls, presumably fixing directly into the C-studs in the MF wall through the plasterboard?
@nod and others who have MF walls, what have you used?
I am think ahead. I am just building an alcove in MF that will be ideal for some 1200 x 300 mm shelves.
9 hours ago, Conor said:
Ply line that wall before boarding
Either that, or use a high-strength plasterboard - I'm currently using GypsoLignum.
If you have only plasterboard, then I've found Fischer DuoTec nylon toggles to be good.
