Big Jimbo Posted August 15, 2023 Posted August 15, 2023 I'm starting to think about heat losses. Not the normal one's, like floor, walls, windows, doors, and roof. The odd ones that i also need to consider. Things like where the wall meets the floor. Where the windows meet the wall reveals. Window lintels. Where the roof meets the walls. Pipe penetrations from inside to outside. Are there any others that people can think of ? Don't want to miss any if i can. Thanks in advance.
SteamyTea Posted August 15, 2023 Posted August 15, 2023 Are you thinking about cold bridges and how to calculate the losses?
Big Jimbo Posted August 15, 2023 Author Posted August 15, 2023 @SteamyTea Yes, Both how to calculate them, and thinking about what i might be able to do to make them a bit better.
SteamyTea Posted August 15, 2023 Posted August 15, 2023 I did a bit about calculating periphery heat losses on here a while back. It is not a a BSI standard, but was close enough. Basically you add the aperture/wall thickness to the total wall area, then calculate as normal. 1
SteamyTea Posted August 15, 2023 Posted August 15, 2023 Just knocked this up, it may help. Periphery Losses.xlsx 1
joe90 Posted August 15, 2023 Posted August 15, 2023 1 hour ago, Big Jimbo said: Things like where the wall meets the floor. Periphery insulation and extending cavity insulation down to the foundation. 1 hour ago, Big Jimbo said: Where the windows meet the wall reveals. Windows sat in cavity as much as possible, tape joins. 1 hour ago, Big Jimbo said: Window lintels. Two separate lintels in each leaf (brick and block only) 1 hour ago, Big Jimbo said: Where the roof meets the walls. Warm roof and insulation continues from cavity into roof . 1 hour ago, Big Jimbo said: Pipe penetrations from inside to outside. Few or None, unless down through an insulated slab and if unavoidable insulated to death. 2
SteamyTea Posted August 15, 2023 Posted August 15, 2023 12 minutes ago, joe90 said: Warm roof and insulation continues from cavity into roof . Yes, and you get the added bonus of a better temperature in the loft.
joe90 Posted August 15, 2023 Posted August 15, 2023 2 minutes ago, SteamyTea said: Yes, and you get the added bonus of a better temperature in the loft. Yes, I wanted my MVHR up there and it’s usage as storage.
Iceverge Posted August 16, 2023 Posted August 16, 2023 @Big Jimbo I think I'm right in saying you have a block cavity design. have you seen the denby dale videos on you tube?
Big Jimbo Posted August 16, 2023 Author Posted August 16, 2023 5 hours ago, Iceverge said: @Big Jimbo I think I'm right in saying you have a block cavity design. have you seen the denby dale videos on you tube? @Iceverge. No. I have tried to find them in the past, but couldn't.
Big Jimbo Posted August 16, 2023 Author Posted August 16, 2023 @Iceverge Just found them and watching now. cheers 1
