seal between toilet and wall
Ours came with a (damaged) foam gasket sheet that I replaced with one cut from this..
3mm white..
https://www.ebay.co.uk/itm/Closed-Cell-polyethylene-foam-sheet-1M-x-1M-insulation-waterproof-rigid-strong/352142516963?var=621587385445&pageci=3c4533a5-13fb-485b-9a3a-4be9e8c36d2d&redirect=mobile
It's not a hard foam, more like medium rubber, but felt similar to the one supplied and more durable.
After tightening up the bolts I used a sealer same as others did above. It's easier to do before fitting the seat..
PS In case not obvious the gasket doesn't form any part of the pipe sealing. There are big clearance holes in it for the pipes.
I made mine oversize, taped it to the wall, fitted WC and trimmed back with a razor blade.
