Nic Posted July 29, 2023 Posted July 29, 2023 Hi anyone have any details of companies using this system, in the Devon Exeter area for a small 2/3 bed detached house self build … at the drawing planning stage at this time
Chanmenie Posted July 30, 2023 Posted July 30, 2023 R Wall ICF pretty common around those parts I believe 1
AlexH1959 Posted September 8, 2023 Posted September 8, 2023 Polarwall very local in Exeter. They only use extruded polystyrene not expanded.
SteamyTea Posted September 8, 2023 Posted September 8, 2023 4 hours ago, AlexH1959 said: Polarwall very local in Exeter. They only use extruded polystyrene not expanded. That means the thermal and mechanical properties are different, depending on orientation.
AlexH1959 Posted September 10, 2023 Posted September 10, 2023 On 08/09/2023 at 19:00, SteamyTea said: That means the thermal and mechanical properties are different, depending on orientation. But better mechanical strength, better moisture resistance and have a board which has a Lambda value of 0.027
FM2015 Posted September 13, 2023 Posted September 13, 2023 On 10/09/2023 at 19:00, AlexH1959 said: But better mechanical strength, better moisture resistance and have a board which has a Lambda value of 0.027 Can you qualify "better mechanical strength"? Isn't lambda only a very small part of the overall calculation for sap? The EPS Vs XPS argument is mostly predicated on manufacturer sponsored research. Not going into that rabbit hole but generally speaking "facts" like the ones started do not paint the whole picture. 1
Nic Posted September 30, 2023 Author Posted September 30, 2023 So anyone using Jackon in the Devon Exeter area?
Tom Posted September 30, 2023 Posted September 30, 2023 Not me, but the Nudura distributor is close by www.thefellpartnership.co.uk 1
Nic Posted October 2, 2023 Author Posted October 2, 2023 So I think I’m looking at Jackon , thermohouse or poly steel I see poly steel are quite local to Exmouth Devon. Anyone know much about thermohouse in the West Country?
SteamyTea Posted October 2, 2023 Posted October 2, 2023 We do have a member that works for an ICF company in the West Country. Just noticed they have replied already.
Nic Posted October 2, 2023 Author Posted October 2, 2023 Which one who has replied is in the West Country, sorry . Thanks again
FM2015 Posted October 9, 2023 Posted October 9, 2023 On 02/10/2023 at 08:56, SteamyTea said: We do have a member that works for an ICF company in the West Country. Just noticed they have replied already. Refusing to advertise 🤣 But there's a number kicking about
