Apprentice Posted July 6, 2023 Share Posted July 6, 2023 Hi all, If you have a row of houses with a water main running across the outside of their front lawn, how do you tap in to that main to get the water to one of the said houses? Is a saddle used? I hope that makes sense? 🙈😋 Link to comment Share on other sites More sharing options...
Temp Posted July 6, 2023 Share Posted July 6, 2023 Not sure about Ireland but in England the water co own the bit from the main to your property boundary so they get to do the connection for you. 1 Link to comment Share on other sites More sharing options...
Apprentice Posted July 8, 2023 Author Share Posted July 8, 2023 Thanks Temp! Sorry, I should of been clearer - how do you tap into the mains? Do you use a saddle and branch pipe work into each house? So if there’s 5 new houses running adjacent to a water main, would there be 5 separate lines drawing from that separately? Link to comment Share on other sites More sharing options...
TonyT Posted July 8, 2023 Share Posted July 8, 2023 I think it depends on your water board, the commercial builds I have done, we install a boundary box in the ground, run pipe from this location to the point of use, and Scottish Water or approved contractor makes the connection. type of connection depending if they can turn water off, how many building it affects. live connections can also be made. Generally not something the user has to worry about, saddle connections are used as they are a convenient way of providing a connection. 1 Link to comment Share on other sites More sharing options...
Conor Posted July 8, 2023 Share Posted July 8, 2023 1 hour ago, Apprentice said: Thanks Temp! Sorry, I should of been clearer - how do you tap into the mains? Do you use a saddle and branch pipe work into each house? So if there’s 5 new houses running adjacent to a water main, would there be 5 separate lines drawing from that separately? Yes . Normally a 25mm tapping or "ferrule" on to the main and a dedicated 25mm MDPE pipe to each property. Link to comment Share on other sites More sharing options...
