Crofter Posted July 7, 2023 Author Posted July 7, 2023 8 minutes ago, Dillsue said: Why would you want to forget? I like to DIY 🙂
Dillsue Posted July 7, 2023 Posted July 7, 2023 3 hours ago, Crofter said: I like to DIY 🙂 Why would that stop you notifying your DNO.  If you can't fill in a G98 and do a single line sketch, you probably shouldn't be doing a DIY install.....both are straight forward to do 1
Crofter Posted July 7, 2023 Author Posted July 7, 2023 4 minutes ago, Dillsue said: Why would that stop you notifying your DNO. Â If you can't fill in a G98 and do a single line sketch, you probably shouldn't be doing a DIY install.....both are straight forward to do Sorry I was assuming that it would be at that point that I would be rumbled and they'd all me who was installing it.
Dillsue Posted July 7, 2023 Posted July 7, 2023 3 hours ago, JohnMo said: Or do what I said in the first post and it's off grid, so no-one cares Maybe I missed something but OP has/wants E7, so grid tied??
Dillsue Posted July 7, 2023 Posted July 7, 2023 2 minutes ago, Crofter said: Sorry I was assuming that it would be at that point that I would be rumbled and they'd all me who was installing it. No, you can DIY the lot. I know of a 100% DIY install with a G98 signed off by the DIYer. DNO accepted it. It's not legit as it should have a spark test and certify but it's seems DNO doesnt care/notice. Â Other DNOs may be more scrupulous but I think they're likely to be pretty appreciative that someone's bothered to notify them regardless whos signature is on the form?? 1
Crofter Posted July 7, 2023 Author Posted July 7, 2023 10 minutes ago, Dillsue said: No, you can DIY the lot. I know of a 100% DIY install with a G98 signed off by the DIYer. DNO accepted it. It's not legit as it should have a spark test and certify but it's seems DNO doesnt care/notice. Â Other DNOs may be more scrupulous but I think they're likely to be pretty appreciative that someone's bothered to notify them regardless whos signature is on the form?? Thanks, so basically it's the same as most wiring then- don't be an idiot! Â And the requirement to get it done by an MCS company still stands if you want to get paid for export?
Dillsue Posted July 7, 2023 Posted July 7, 2023 19 minutes ago, Crofter said: Thanks, so basically it's the same as most wiring then- don't be an idiot! Â And the requirement to get it done by an MCS company still stands if you want to get paid for export Yep, MCS(or equivalent) for paid export. I'm sure someone posted about there being another outfit that does the certification but can't remember the name.
JamesPa Posted July 7, 2023 Posted July 7, 2023 24 minutes ago, Dillsue said: Yep, MCS(or equivalent) for paid export. I'm sure someone posted about there being another outfit that does the certification but can't remember the name. Flexorb is the alternative outfit. Octopus wont accept them though, the decision whether or not to accept is down to the supplier.
JohnMo Posted July 7, 2023 Posted July 7, 2023 1 hour ago, Dillsue said: Maybe I missed something but OP has/wants E7, so grid tied?? On 06/07/2023 at 16:47, JohnMo said: My-PV do a DC immersion which can also take an AC input, The immersion I referenced is AC connected for backup. It will run the PV array fully off grid.. You set you target temp for AC, independent of what the DC (PV) does or achieves.  So completely fulfills what the OP asked for. PV hot water but also can be charged by E7 if required.
Dillsue Posted July 7, 2023 Posted July 7, 2023 1 hour ago, JohnMo said: The immersion I referenced is AC connected for backup. It will run the PV array fully off grid.. You set you target temp for AC, independent of what the DC (PV) does or achieves.  So completely fulfills what the OP asked for. PV hot water but also can be charged by E7 if required. OPs mentioned "feeding the house first" and repeatedly said grid tied?? Having the PV hooked up just to a diverter seems a waste as theres no where for the PV to go once the DHW tank is hot, or is that not how it works??
Crofter Posted July 8, 2023 Author Posted July 8, 2023 9 hours ago, JohnMo said: The immersion I referenced is AC connected for backup. It will run the PV array fully off grid.. You set you target temp for AC, independent of what the DC (PV) does or achieves.  So completely fulfills what the OP asked for. PV hot water but also can be charged by E7 if required. That immersion looks good but it's really really expensive. I'm thinking the Cool Energy DiverTech will do the job at a third of the cost.
