For my patio sub base I'm using a lot of the local flint that I'll whack down. Up until now I've been picking out the chalk but do I need to? Seems hard enough a material, should whack down well and remain in place and sticky when damp. Thinking a whacked flint / chalk sub base then  sand/cement dry mix pre the slabs.
I would have thought the flints would whack down better with chalk in the mix as it will fill in the gaps like having fines with type1.
On another forum, in part answer to the same question, somebody wrote:
"A good quality geo membrane under the sub base is the most important factor".
Really? Without diving into the paving expert site, is that really correct?
No point in the membrane.  It works OK as a separation layer, like if you are on clay.  Flint and chalk will be good as long as the chalk is not too putty-like.
I am on clay. Thin top soil, clay, chalk. Flints in every layer
