Evil hybrid roof construction
bmj1
Okay, I think this is very bad, but want to get opinions:
  • We have a finished flat roof: 100mm warm deck above, and for some reason, 25mm between the joists ?!
  • The insulation between doesn't appear to be pressed up tight against the plywood above (which I understand is the thing to do when doing this), but instead, there is a gap due to the piece of wood running across above the joists
  • I'm concerned about interstitial condensation
Is the only sensible option is to remove the 25mm insulation between, and live with 100mm insulation above... and make up on the SAP elsewhere ?
Edited by bmj1
