bmj1 Posted June 13, 2023 Posted June 13, 2023 Our GF build up is: Beam & block DPM PIR insulation Liquid screed Floor finish Should the PIR insulation layer be foil or tissued faced? One-side or both sides ? Or should we be putting a plastic membrane between the PIR and liquid screed, in which case tissue facing is fine ? Thank you in advance.
nod Posted June 13, 2023 Posted June 13, 2023 Membrane on your BB taped to your dpc Then insulation Foil both sides Joints taped Then another membrane Then pipes
bmj1 Posted June 13, 2023 Author Posted June 13, 2023 I'm a bit confused by the K103 product: K103 insulation is designed for floor insulation in floor buildups. You can install K103 phenolic foam boards in block and beam, solid concrete, suspended ground floors and timber floors. The insulating core is surrounded by glass tissue facings. Why do they surround it by glass tissue facings ?
Chanmenie Posted June 13, 2023 Posted June 13, 2023 1 hour ago, bmj1 said: Our GF build up is: Beam & block DPM PIR insulation Liquid screed Floor finish Should the PIR insulation layer be foil or tissued faced? One-side or both sides ? Or should we be putting a plastic membrane between the PIR and liquid screed, in which case tissue facing is fine ? Thank you in advance. Do you have bad ground (clay) ? if not why have block and beam, ground bearing slab is more efficient. I put a DPM under the PIR and a slip membrane ontop of the PIR, but I had concrete not screed. The slip membrane prevents the concrete from damaging the foil face of the PIR, I assume screed would do the same
bmj1 Posted June 13, 2023 Author Posted June 13, 2023 1 minute ago, Chanmenie said: Do you have bad ground (clay) ? if not why have block and beam, ground bearing slab is more efficient. I put a DPM under the PIR and a slip membrane ontop of the PIR, but I had concrete not screed. The slip membrane prevents the concrete from damaging the foil face of the PIR, I assume screed would do the same Yes, London Clay
Chanmenie Posted June 13, 2023 Posted June 13, 2023 (edited) 25 minutes ago, bmj1 said: Yes, London Clay Yeah that’s not great hence the BnB But yes I’m pretty sure you need a slip membrane, 500g polythene much thinner than DPM. Celotex or Mannok is usually much cheaper than Kingspan, how thick can you go with the PIR Edited June 13, 2023 by Chanmenie
bmj1 Posted June 13, 2023 Author Posted June 13, 2023 (edited) 1 hour ago, Chanmenie said: Yeah that’s not great hence the BnB But yes I’m pretty sure you need a slip membrane, 500g polythene much thinner than DPM. Celotex or Mannok is usually much cheaper than Kingspan, how thick can you go with the PIR Thanks, makes sense. DPM below and above then. I've grabbed some 75mm Kooltherm from Seconds and Co.. (£400 / pallet of 20 sheets). Can't go wrong at that price. My max was 90mm, but that was pushing it on tolerance. This is much more comfortable. Gets us a floor u-value of 0.157, which we'll compensate for with solar PV. I'd rather have the extra ceiling height than a slightly more energy efficient house. Edited June 13, 2023 by bmj1
Dave Jones Posted June 13, 2023 Posted June 13, 2023 shame the correct flooring detail below FFL is often overlooked. see a lot of threads here with same. A simple thing to get right at the time, very hard after. Yet another basic building function architects are clueless on.
