Anyone have any advice on this? Need to drive 100mm stainless steel screw through softwood battens then into roof rafters. Guessing it may be best to pilot hole first?
I would do clearance holes through the battens - maybe 5mm so you can load the screws.  Assuming you have lots to drill, you could stack the battens and do 3 at a time.  Once you have set one up you can use this as a template.  If screwing into the rafter without a pilot is tricky you could do a 4mm pilot but not full depth.
