Have a couple of nuaire mvhr units and looking at upgrading filters. Would this be suitable to attach into the existing frames? If not any links appreciated.
You may need to check that you unit is suitable for F7 as that is pretty strong [not sure if that's the right word] filter, and may affect performance if the unit isn't rated for it.
The open area of the filter will be much smaller, than current filters, (assume not F7) causing a large pressure drop, you may have to up the fan speed considerably to get the same flow rates as you currently have.
