Hi :)
Can anyione advise on the need, or not, of a membrane on the outer face of the inner leaf in a bead filled new cavity?
Apparently it is to protect the inner leaf from damp, as moisture could track across the bead - new to me
TIA, JAmes
Edited by Jimbo37
No membrane required, but you need to restrict the amount of moisture getting into the outer leaf, so either render for blockwork or a coat of Stormdry or similar if it is brickwork.
