 I had this from building control. What do I need to comply ? Does the cabling need to be connected to any sort of termination point ready for a charger to be added at a later date ?if so what do I need.
‘The requirement is one charging point for each unit, plus cabling to be provided per associated vehicle space within the boundary of the properties.’
I read that as you must provide 1 working charge point, PLUS the cabling installed ready to add additional charging points for each vehicle space you have so those can be upgraded later.
for the additional ones, I would just say suitable SWA cable with the ends sealed to keep water out, from the parking space to the consumer unit, ready to be terminated when you want them.
Ok thanks. One of the three parking spaces is counted as the garage so would I have a charger point set up inside the garage ? Then I could provide cabling to the pillars each side of the garage doors for future chargers ?
Data cable too probably unless the unit works off 4G
personally I would fit ducts to proposed positions, pull in cable such as EV ultra, or separate Swa/ data.
Edited by TonyT
