richo106 Posted April 19, 2023 Posted April 19, 2023 Hi All As you have probably noticed from my other posts I am sorting my quantity and type of insulation required. I want to insulate between ground and first floor I have 225mm posi joists, there will be UFH spreader plates (installed from below) MVHR ducting and all other services (cabling, pipes etc..) What is the best insulation between floors? and guessing I would install all services and then push the insulation in around everthing? Many Thanks
richo106 Posted April 19, 2023 Author Posted April 19, 2023 One option I thought was to install my UFH spreader plates and then push up 100mm Isover APR insulation up to it https://insulation-uk.com/products/isover-acoustic-partition-roll-apr-1200 Then install my MVHR ducting and cabling/pipes etc...
richo106 Posted April 19, 2023 Author Posted April 19, 2023 I have just found this option from @Nickfromwalesand this sounds exactly how I want to do it.
ETC Posted April 19, 2023 Posted April 19, 2023 Consult the posi-joist literature for sound and fire resistance requirements.
richo106 Posted April 19, 2023 Author Posted April 19, 2023 One issue I have come across is the Isover APR insulation is that it is pre cut at 600 but my joist centres are 400. would it be better to use standard loft insulation (isover space saver) that is perforated at 400mm? I know the acoustic performance won’t be as good but will it more suitable to install?
