Canski Posted April 12, 2023 Posted April 12, 2023 These came into effect from 26/12/2022 for proposed new dwellings only. We are required to provide a 'connectivity plan' Has anyone else been through this yet ? My LABC are asking for it.
Alan Ambrose Posted April 12, 2023 Posted April 12, 2023 Ah I've missed that. As this is a new thing, if you can't find an example to amend, then you can probably make it up as you go along. Then everyone will copy that I think a house plan, with a few lines for network cables / fibre optic cables will do fine. You're probably planning to put those cables in anyway. The Connected Home – Building Regulations Part R maybe? 1
Alan Ambrose Posted April 12, 2023 Posted April 12, 2023 (edited) Includes wireless ffs. 'Must be able to deliver 30 Mbps', i.e. very little. I was watching an Artisan Electrics video yesterday on a French property - they had slim green flex conduit (maybe 20mm) as standard from somewhere on the outside of the building to the CU cabinet so a fibre cable could be pulled in easily at any later date. Plus some already installed network cables led to the CU cabinet and some space in that cabinet and a power outlet ready for a router/switch. I guess most of the macbuilders still don't bother to put in network cable. The usual sledgehammer to crack a walnut BC tactic. Edited April 12, 2023 by Alan Ambrose
Canski Posted April 12, 2023 Author Posted April 12, 2023 9 minutes ago, joth said: There's a good discussion of it last month: Ahh thanks @joth I missed that in my search. 1
