We gyplined over it 😄
Alternative would to spend a day with a kango chipping it right back. We didn't do any wet palstering at all so no idea how you'd fill the ends - I'm guessing expanding foam the trim back.
9 minutes ago, MortarThePoint said:
I'm avoiding spray foam so not that. It does overhang slightly in one area.
I need to wet plaster so more tricky.
@nod any tips?
We normally just nip the edges every 50 mil top and bottom with a grinder and break off with a chisel Hours topps
Then fix a a sheet of stainless mesh over 2.4 x 600 Then scratch over Don’t fill the holes prior
Is it Stainless mesh because it's not sealed on the other side?
It just stops it rusting over time
We normally use stainless screws and 40 mil washers
A galvanized mesh is ok also if your having trouble getting stainless
But stick with stainless fixings
Edited by nod
Is that because of the hollow core holes or would you use stainless mesh when meshing other interior walls
Mainly the hollow core
Anything internal can have a board over it
You can also mesh and render over plasterboard internally
Ah, the hollow core holes I asked about are internal but in a wall to be wet plastered. So should that be stainless mesh if outside being rendered and galvanised mesh inside if being wet plastered? Or still go with stainless mesh if covering hollow core holes, but galvanised mesh OK internally elsewhere?
