Pocster Posted March 27, 2023 Posted March 27, 2023 I’ve messed up a bit 🙄 Some internal below ground light well windows are too tight to the wall when open . Wall return is 9.5mm plasterboard . My BM won’t ( can’t ! ) get thinner plasterboard . Is there any other product I can use ( 5mm or less thickness ) that a plasterer can still skim without issue ?
Russell griffiths Posted March 27, 2023 Posted March 27, 2023 Why plaster it ? 6mm mdf ? 6mm mdf with veneer ? those shower panel things. What sort of finish do you want ?
Redbeard Posted March 27, 2023 Posted March 27, 2023 Along same lines as @Russell griffiths, I got some fibre cement boards as verge undercloaks. I just put the leftover one in a 'safe place' yesterday, and cannot find it to measure, but I think they were 3-4mm. Thinnest tile-backer I have seen is 6mm.
Pocster Posted March 27, 2023 Author Posted March 27, 2023 1 hour ago, Russell griffiths said: Why plaster it ? 6mm mdf ? 6mm mdf with veneer ? those shower panel things. What sort of finish do you want ? Rest is all plasterboard . So really just want to change the 1 piece ( per window ) - otherwise more work
Pocster Posted March 27, 2023 Author Posted March 27, 2023 Can a plasterer skim tile backer board ? . You can get that in 5mm …. 🤔
markc Posted March 27, 2023 Posted March 27, 2023 Yes you can skim backer board, what’s behind the board? Unless it’s a void then good old browning and then skim 1
Pocster Posted March 27, 2023 Author Posted March 27, 2023 21 minutes ago, markc said: Yes you can skim backer board, what’s behind the board? Unless it’s a void then good old browning and then skim Timber . I’ll glue the board to it to avoid the fittings . Assuming that means he can skim it even thinner .
markc Posted March 27, 2023 Posted March 27, 2023 2 hours ago, pocster said: Timber . I’ll glue the board to it to avoid the fittings . Assuming that means he can skim it even thinner . If it’s timber then the backer board is the best plan 1
