Post and beam Posted March 21, 2023 Posted March 21, 2023 I have a quote for their Afino Tec windows at £44500 + VAT, fitted. Sounds like a lot to me, do the window companies still play the silly games they always used to?
Temp Posted March 21, 2023 Posted March 21, 2023 If this is a new build they shouldn't charge VAT on a supply and fit on one order.
Post and beam Posted March 21, 2023 Author Posted March 21, 2023 Well spotted. They do make a big point of saying their windows are installed by their own employees and not contractors, so deffo a one stop shop. Actually this is an attractive feature of the company. Expensive on first round of haggle though.
Post and beam Posted March 21, 2023 Author Posted March 21, 2023 TG 16 windows and 3 external doors. Front, utility and french doors to rear. Typical text in the schedule is like this Configuration: DLS/DKR 1230 1/2 1/2 Uw,N: 0.95 W/(m²K) n. EN ISO 10077-1 width: 1230 mm, height: 1050 mm width partition: 1, measurements: 1/2:1/2 i307028 Thermal insulation/Security glazing KlimaTherm 0.7 Secur-ai VSG (33.1) g-Value acc. to DIN EN 410 in percent: 49, Ug-value: 0.7 W/(m²K) Sound insulation value (glass): 36 dB Aluminium spacer type: vertical -/horizontal Bar 3 (24mm) colour of bars: outside M4 quartz grey wood structure / inside white number of horizontal bars: 1
Seren161 Posted March 21, 2023 Posted March 21, 2023 You might be able to knock 10 percent of that quote …not sure you’d get more..
craig Posted March 21, 2023 Posted March 21, 2023 (edited) Being generous here, 16 windows at £1.5k each (some will be higher, others lower), £24K, £8k for your doors, £32K. 2 men x 4 days @ £700 (3 days install, 1 day offload and setting out), £2.8K excluding travel call that £200, accommodation £250 a night, call that £1K and delivery £2K. I would say it should be around £36/£38K, £44.5K sounds a bit steep without seeing schedule/quote, for 19 items to be honest. Edited March 21, 2023 by craig
nod Posted March 22, 2023 Posted March 22, 2023 Ask them for there supply only price You will probably be quite shocked We had two sets of bifolds on our last build The fitting and survey price came to £1900 plus vat They wouldn’t zero rate I’d never fitted bifolds before It took myself and my wife less than a day to fit both
Post and beam Posted March 23, 2023 Author Posted March 23, 2023 On 21/03/2023 at 23:25, craig said: Being generous here, 16 windows at £1.5k each (some will be higher, others lower), £24K, £8k for your doors, £32K. 2 men x 4 days @ £700 (3 days install, 1 day offload and setting out), £2.8K excluding travel call that £200, accommodation £250 a night, call that £1K and delivery £2K. I would say it should be around £36/£38K, £44.5K sounds a bit steep without seeing schedule/quote, for 19 items to be honest. Thanks dude, very comprehensive
