Hi,
Have posted this on the SIP forum but thought I would also post here....
I have a SIP outbuilding with a vaulted ceiling and need to attach 2inch battens to the roof for fixing plasterboard (to skim). The roof panels have 11mm OSB and need advise on how best to secure the battens to the ceiling?
I have seen suggestions of simply using 70mm wood screws and also using the black phosphate drywall screws together with PVA glue to ensure a greater pullout resistance?
Thanks in advance
Just need screws long enough to protrude 20mm beyond the face OSB sheet - that was the tech advice given to me by a screw company who had tested the pullout strength etc. I was pointed to them by the tech bods at Kingspan Timber Solutions Tech dept.
For 50mm battens I'd go with 90mm.
Do you need 50mm battens for the ceiling? I used 47mm for walls and 22mm for the ceiling purely because I had no requirement for a deeper service cavity on the ceiling.
Don’t use batons
Ise 100 mil x 25 Fix with 65 mil ring nails
No need for glue
Use 35 mil timber drywall screws
You can hang an elephant off those
Edited by nod
2 hours ago, nod said:
Don’t use batons
No need for glue
I agree with the 100x25mm - got to be screws for SIP though.
I will be using the ultra slim LED downlights which have a depth of ~30mm - wouldn't the 100x25mm be cutting it to fine to be able to install them?
To clarify, I was thinking of using 50mm x 50mm battens
