dai jinks Posted March 8, 2023 Posted March 8, 2023 I've got a really weird question hanging around me about something else but don't know where to post it etc and it is, I've converted the loft with a shower bathroom about a metre of flat ceiling ( for door and shower unit etc) then it rakes about 30 degrees down to the from, passing by the toilet and opposite sink, leaving 2 m of rake space until the supporting wall on the steel beam for the existing roof etc. In this approx 2m x 2 m space, am I allowed by regs to have a single bed to use now and again? It could have a sliding barrier or similar ( like in victorian times when people slept in inclosed wooden compartments within he room occupied. Are there regs basicly to stop this practice of resting in such a spot.? There is a velux above and the door could be changed to an fd 30. OK just a thought. Cheers
Temp Posted March 8, 2023 Posted March 8, 2023 Converting the loft to a "habitable" room (like a bedroom) normally requires Building Control Approval but not Planning Permission. However the Building Regulations for a three storey house are stricter than for a two storey house. The main concern is adequate escape routes if there is a fire. Dont want someone trapped up there. In some cases converting the loft requires alterations to the hall and staircase on the ground floor.
ProDave Posted March 8, 2023 Posted March 8, 2023 Your big issue will be electrics. A bathroom cannot have a socket within 3 metres of the bath. It sounds like your room is not big enough for that. This was an issue for me once where a customer put a shower in the corner of a bedroom. It was just, and only just, possible to put a double socket in the opposite corner of the room to the shower, which of course was not where he wanted sockets to be. 1
