45 minutes ago, Moonshine said:
Not really found anything on the best way to do this, and was thinking of using something like these
https://www.screwfix.com/p/easydrive-tx-countersunk-concrete-screws-7-5-x-80mm-100-pack/8400h
anyone got a better way?
I have just used these at 120mm to fix some 6x2 supports to a rendered lightweight block wall.  I used a 7.5mm wood bit for the clearance holes, an 8mm masonry bit just to go through the render and then a 6mm for the length of the screw plus 10mm.   You may need different if it is concrete block.  If you are doing lots, make sure you have a few of the driver bits.  I think they are TX30 and there is only 1 in the box.
We used those concrete screws, but 100mm long. You need a bit more depth. Also expanding foam the whole way round.
