10 minutes ago, Drellingore said:
Does anyone know what F.W.W.C. might stand for on a manhole cover over a roadside surface water sewer?image.thumb.jpeg.996f9aa28f859f31ab400c974432f702.jpeg
Pretty sure it’s not a standard term so something ….. … water company?
31 minutes ago, SteamyTea said:
(expletive deleted)ing Waste Water Cover
 Ha!
Is it Flow Control Waste Cover? but in the wrong order.
Ooh, good shout. Having lifted the thing, it appears to be a brick-lined weir for surface water, that then discharges into a pipe under a road, and finally infiltrates under a field (I think). No idea what the acronym might be, but it seems to be serving that purpose.
Yeah, it doesn't match any extant water companies, but it is close to Folkestone. Folkestone Waste Water Company? Sounds plausible. No-one seems to know that it exists, or where it leads - Southern Water (the sewage company for the area) don't have it on record, National Highways don't have it on record, and Dover District Council only know that there's a gulley which they empty, but otherwise have zero information.
Funny how this stuff gets lost to time!
You'd rarely have the name / type of equipment stamped on the MH cover. Purely because they are a stock item and can be moved easily. It's either the name of the lid manufacture or the water company.
14 minutes ago, Blooda said:
WaterWorks
Had a girlfriend that must have worked for them, she turned them on all the time.
(make of that statement as you will)
