Lal Posted February 22, 2023 Share Posted February 22, 2023 We recently bought a 4 year old new build and I’m looking into sorting out some flooring concerns! I believe our foundation is block and beam, although no one can seem to confirm it! However, while I walk, the kitchen cabinets and the dining room rattles/vibrates. I’m not sure why this is! looking to find out more about this ! I’ve attached a photo of our home during its foundation build, can anyone tell me what type of foundation this is and how to sort out the bounce? Link to comment Share on other sites More sharing options...
SteamyTea Posted February 22, 2023 Share Posted February 22, 2023 41 minutes ago, Lal said: Looks like a floating pontoon at a marina. Looks to be B@B, but I am viewing on my phone. Link to comment Share on other sites More sharing options...
Conor Posted February 22, 2023 Share Posted February 22, 2023 (edited) Some sort of block and beam floor. Can't tell if the infill between the T beams are standard blocks, large blocks or insualtion blocks. Looking at the very bottom RHS suggests an insulated type infill, e.g. https://www.cemex.co.uk/suspended-floor-systems Further reading here https://www.bdonline.co.uk/cpd/cpd-4-2017-insulated-suspended-floor-systems/5087724.article Pretty standard stuff these days, tho not that widespread. Normally overlaid with more insualtion and then a thin screed. Inherently "bouncy" over longer spans, natural quality of reinforced concrete beams. Bugger all you can do about the bounciness if that's what is annoying you. Unless the builder has exceeded the manufacturers / engineers span tables or inadequate intermediate supports. You'd need a camera survey done via the floor void to confirm. As it's a recent build, the design drawings and calculations etc should be available via building control. Edited February 22, 2023 by Conor 1 1 Link to comment Share on other sites More sharing options...
Lal Posted February 22, 2023 Author Share Posted February 22, 2023 1 hour ago, Conor said: Some sort of block and beam floor. Can't tell if the infill between the T beams are standard blocks, large blocks or insualtion blocks. Looking at the very bottom RHS suggests an insulated type infill, e.g. https://www.cemex.co.uk/suspended-floor-systems Further reading here https://www.bdonline.co.uk/cpd/cpd-4-2017-insulated-suspended-floor-systems/5087724.article Pretty standard stuff these days, tho not that widespread. Normally overlaid with more insualtion and then a thin screed. Inherently "bouncy" over longer spans, natural quality of reinforced concrete beams. Bugger all you can do about the bounciness if that's what is annoying you. Unless the builder has exceeded the manufacturers / engineers span tables or inadequate intermediate supports. You'd need a camera survey done via the floor void to confirm. As it's a recent build, the design drawings and calculations etc should be available via building control. thank you so much for the response. That’s really helpful and more information than I’ve received from the developers 🙁I’m just worried about how/if the bounce will impact the structure of the house in the long-term. Link to comment Share on other sites More sharing options...
Nickfromwales Posted February 22, 2023 Share Posted February 22, 2023 29 minutes ago, Lal said: thank you so much for the response. That’s really helpful and more information than I’ve received from the developers 🙁I’m just worried about how/if the bounce will impact the structure of the house in the long-term. Do you know if there is a screed down? Do you have UFH? Link to comment Share on other sites More sharing options...
Nickfromwales Posted February 22, 2023 Share Posted February 22, 2023 1 hour ago, Conor said: insualtion blocks. Looking at the very bottom RHS suggests an insulated type infill, e.g. https://www.cemex.co.uk/suspended-floor-systems Yup, looks like it. Shame really, as they deserve kudos for using that instead of scabby breeze blocks! Link to comment Share on other sites More sharing options...
Lal Posted February 23, 2023 Author Share Posted February 23, 2023 44 minutes ago, Nickfromwales said: Do you know if there is a screed down? Do you have UFH? Not sure about the screed but I think so (looking at this picture). no UFH. It is a timber framed house, so not sure if this has anything to do with the ‘bounce’ but having spoken to some of my neighbours, they don’t seem to have the same issues with the bounce Link to comment Share on other sites More sharing options...
Susie Posted February 23, 2023 Share Posted February 23, 2023 If your neighbours floor seems ok what could be different e.g. do you have a floating wooden floor. Link to comment Share on other sites More sharing options...
Nickfromwales Posted February 23, 2023 Share Posted February 23, 2023 1 hour ago, Susie said: If your neighbours floor seems ok what could be different e.g. do you have a floating wooden floor. +1, and I was going to also ask if the kitchen units are mounted on top of the floating wooden floor? Link to comment Share on other sites More sharing options...
Lal Posted March 8, 2023 Author Share Posted March 8, 2023 No idea why! I’m trying to attach a video to show, but the size seems too big! could this be anything to do with foundation issues at all? Link to comment Share on other sites More sharing options...
George Posted March 9, 2023 Share Posted March 9, 2023 Sounds more like the cabinet legs aren't fully extended down onto the floor. Can you take the kick board off and check the legs? Beam and block can have some bounce but it shouldn't be excessive. Even solid floors will vibrate under impact forces. Link to comment Share on other sites More sharing options...
