Hello. I am about to install a 7.3kw east/west array. There will be an equal number of 8 panels
on each side of a shed roof approx 15degree pitch. I am using a solid 6kw hybrid inverter. My question is about the wiring...Best to connect each side up in series but then connect both sides in parallel? There is no overhead shading.
Thanks.
It's a solis hybrid 6kw 5G inverter SOL-6K-RHI-48ES-5G-DC. 600vDC max per string...I can't see how many strings it can support although two connections on the base of the unit (2x DC positive and negative) for panel connections so I'd say 2 strings
Edited by Huckleberrys
Start up voltage is 120V.
So make sure your modules, when in series, can supply at least that.
And make sure they do not supply more than 11A per string.
