Alwayslearning22 Posted February 8, 2023 Posted February 8, 2023 Im building a walk In wardrobe. Can floor joists hold 300kg of ikea wardrobes? Without causing any issues? Many thanks my
MikeGrahamT21 Posted February 8, 2023 Posted February 8, 2023 Depending on which way the joists are running, you could well be splitting that load over quite a few, or maybe just 2. If you can see where the nails/screws are in floorboards, you'll know which way joists run.
Carrerahill Posted February 8, 2023 Posted February 8, 2023 (edited) 9 minutes ago, Alwayslearning22 said: Im building a walk In wardrobe. Can floor joists hold 300kg of ikea wardrobes? Without causing any issues? Many thanks my Over what sort of footprint? 300kg over 0.25m² versus 300kg over 2m² are quite different. Un upright piano can weigh 250kg (some can weight in at 400 odd) - but each wheel may only be 62kg odd. Edited February 8, 2023 by Carrerahill
Alwayslearning22 Posted February 8, 2023 Author Posted February 8, 2023 19 minutes ago, Carrerahill said: Over what sort of footprint? 300kg over 0.25m² versus 300kg over 2m² are quite different. Un upright piano can weigh 250kg (some can weight in at 400 odd) - but each wheel may only be 62kg odd. About 300kg over 2 m2. Oh and I should add it’s going to In my attic bedroom.
