My newly installed ASHP Mitsibushi Ecodan has unfortunately been sprayed with tap water from a cracked outside tap after the current cold minus temperatures.
I could hear running spraying water and looked outside to see one side of the unit covered in ice an inch thick.
My question is. What should I do?
Leave it to that naturally, which at the moment will take ages?
Turn it off all together?
Poor very slight luke warm water over the side - no electrical wires or connectors on that part?
The fan isn't inhibited and is running just fine, however I think it sounds more noisy at the moment.
Any advice would be very welcome.
Thank you
If your hose isn't frozen, you could try spraying it with water. Even cold water (maybe 8 degrees at this time of year?) is pretty efficient at melting ice.
Thank you all.
I poured some tap water over it for a few minutes to de-ice it.
Only a couple of fins are bent ever so slightly. I hope this doesn't impact on it working as it should?
Thanks
