GrantMcscott Posted January 14, 2023 Posted January 14, 2023 (edited) Hi We have Velux VFE Windows see pick. On the Windiest part of the house the gasket that seals the Windows let’s quit a big draft in at the corners. Wondering if if anyone else has had this issue with Velux and what they did about it. Going to to contact them on Monday as had to put scarfs on the window sills to stop drafts Edited January 14, 2023 by GrantMcscott Added pic
Sparrowhawk Posted January 23, 2023 Posted January 23, 2023 Did you get anywhere? I am pretty sure I have air leaks too but Velux technical services are impossible to make see reason.
GrantMcscott Posted January 30, 2023 Author Posted January 30, 2023 On 23/01/2023 at 21:05, Sparrowhawk said: Did you get anywhere? I am pretty sure I have air leaks too but Velux technical services are impossible to make see reason. No, Still not fixed. Our house is in a valley and when the wind is above 20Mph the seals do not hold on the Velux windows and the wind howels in Going to email Velux today.
GrantMcscott Posted February 1, 2023 Author Posted February 1, 2023 On 23/01/2023 at 21:05, Sparrowhawk said: Did you get anywhere? I am pretty sure I have air leaks too but Velux technical services are impossible to make see reason. Got this responce from Velux To provide you with some more context regarding the issue being experienced. The vertical windows are classed as class 3 for air permeability, this means that they can allow up-to 3x as more air through them as their sloping counterparts which are class 4. However we are aware of the issue, and are currently working with our production team to provide a solution on how to improve the air tightness of the windows. I understand this is not ideal at the moment, however once we have a solution we can then arrange a service call to have our technician attend your property.
