lakelandfolk Posted January 12, 2023 Posted January 12, 2023 Is there a Horizontal UVC available that is compatible to an ASHP
eniacs Posted January 16, 2023 Posted January 16, 2023 Joule do one: https://www.jouleuk.co.uk/products/cyclone-hi-gain-horizontal/
PeterW Posted January 16, 2023 Posted January 16, 2023 Telford will make you one - just spec the high surface coil
Nickfromwales Posted January 18, 2023 Posted January 18, 2023 Don't forget you'd be best off installing a pump across the tank connections to get it to force-stratify during the heating cycle.
lakelandfolk Posted January 26, 2023 Author Posted January 26, 2023 Thanks all, yes you are correct Telford make one, Tempest 200L heat pump cylinder. 510mm high x 1500mm . About £1200.
