BadgerBadger Posted January 11, 2023 Posted January 11, 2023 Today's question of the day! Our first section of DPC are going in, but should I be ensuring the edge is visible in the finished brickwork? It's ended up recessed about 10mm into the mortar, obviously a small potential breach for damp but it's also not obvious to any casual observer / building control / warranty inspector that its actually present. It's only a section in so far and we're only a couple of courses above, so easier to fix now rather than later, or is it just generally acceptable? Thank you!
Mr Punter Posted January 11, 2023 Posted January 11, 2023 If there are engineering bricks below it will be fine.
saveasteading Posted January 11, 2023 Posted January 11, 2023 I think it should always be visible, otherwise there is a dampness link past it. If the bed mortar is recessed (bucket handle) then that might expose it, while also concealing it a little.
Canski Posted January 11, 2023 Posted January 11, 2023 I’ve only done it once in 40 years of bricklaying and that was at the request of a rather anal drainage engineer. It looked horrible. In the old days a felt doc was often left exposed with a bed joint below and one on the top. In my opinion it also looked ghastly. With engineerings below it really shouldn’t be necessary.
