funkyboy Posted January 10, 2023 Posted January 10, 2023 Hi All, My elderly parents are having some work done this week for a barrier damp course. The builders said there's no lintel above the external back door. House is 90 years old current door been in about 20 years. Any advice please worried sick about them
markc Posted January 10, 2023 Posted January 10, 2023 The wall hasn’t moved in the last 20 or even 90 years so I wouldn’t worry or even think about it.
MikeGrahamT21 Posted January 10, 2023 Posted January 10, 2023 That might not be the case. I had the same thought about my bathroom window, I have just had a lean to extension on the side of the bungalow so they needed concrete lintels installing for the additional load, and when the builders took the bricks out they found a steel angle lintel, it was just small enough you couldn't see anything was there. Stick a drill in the mortar directly above the timber, and you should eventually hit metal.
George Posted January 10, 2023 Posted January 10, 2023 That brickwork hasn't been touched since construction so I doubt there's a lintel there. It'll be arching over and the upvc carrying some load - does the door stick at all? Now is the time to do it. Would take a builder half a day to sort out. 1
Gus Potter Posted January 13, 2023 Posted January 13, 2023 On 10/01/2023 at 09:51, George said: That brickwork hasn't been touched since construction so I doubt there's a lintel there. It'll be arching over and the upvc carrying some load - does the door stick at all? Now is the time to do it. Would take a builder half a day to sort out. Can you post a photo of the whole wall so we can see what is above and what kind of loads may be acting on the opening? I ask as there is a "funny joint" to the right side on the brickwork. Don't be shy as you'll get loads of good advice from @George and some form me too and others.
